I'm old fashion. I do this in a word document and keep it on a thumb drive. No cell phones or cloud storage in this house. Not secure or reliable. I take the specs from the book and then change it to my liking.
2005 Ford Ranger (3.0L)
Bought May 2005 40 Miles
Scheduled Maintenance
5,000 Miles or 6 Months (1 Year)
Change Oil/Filter (due March 2019 or 89,000) (See Testing)
Rotate Tires (due 88,000)
(Lube Lower Ball Joints) (due 88,000)
15,000 Miles
Lube Ball Joints (see 5,000)
30,000 Miles
Change Air Filter (due 105,000)
Change Fuel Filter (due 115,000)
(Change Brake Fluid) (or 3 Years) (due October 2017 or 90,000) (See Testing)
(Change Coolant) (or 3 Years) (due June 2017 or 90,000) (See Testing)
60,000 Miles
Clean/Grease Wheel Bearings
(Change Rear Axle Oil) (due 100,000)
(Change Trans Fluid/Filter) (due 120,000)
(Change Power Steering Fluid) (due 120,000)
100,000 Miles
Change Spark Plugs (due 170,000)
Change PCV (due 164,000)
Change Coolant (50,000 miles thereafter) (See 30,000)
Change Accessory Drive Belt (due 100,000)
(Change O2 Sensors) (due 100,000)
150,000 Miles
Change Front Wheel Bearings/Seals
EPA Fuel Economy
Old New
18/22 16/21
Engine 5 Quarts 5w20 SM (Mobil1 5w30 HM)
Coolant 2.5 Gallons
Trans 5 Quarts Mercon V (Mobil1 ATF)
Rear Axle 2.5 Quarts 80w90 (Mobil1 75w-90)
Power Steering ½ Quart Mercon (Mercon V)
Brake Fluid ½ Quart DOT 3
Fuel Tank 19.5 Gallons
Spark Plugs Gap .042-.046 (Indexing - Gap Faces Intake Valve)
Denso Iridium IT16TT (4713)
Wish List
Programmer
Cruise Control
Rear Spring Air Bags
Testing
Lubricheck
Changed March 2, 2018 (83,750)
September 2, 2018 (85,063) - 3
June 9, 2018 (84,581) - 1
April 30, 2018 (84,187) - 2
Brake Fluid
Changed October 1, 2014 (60,266)
July 14, 2018 (84,869)
Water Copper 30
Coolant
Changed June 21, 2014 (58,290)
Protection 40%
pH 7
ToDo
History
June 18, 2018 (84,670)
Clean MAF Sensor
May 16, 2018 (84,500)
R/R Rear Brake Shoes (Wagner ThermoQuiet PAB705R)
R/R Fuel Filter
March 7, 2018 (83,846)
Ford Airbag Recall (O.C. Welch Ford-Lincoln)
R/R LH Airbag Inflater
R/R RH Airbag Inflater
R/R Motor Oil (Mobil1 5w30 HM)
R/R Oil Filter
15,000 Miles
30,000 Miles
60,000 Miles
100,000 Miles
150,000 Miles
EPA Fuel Economy
Old New
18/22 16/21
Coolant 2.5 Gallons
Wish List
Programmer
Cruise Control
Testing
Lubricheck
Brake Fluid
Water Copper 30
Coolant
Protection 40%
pH 7
ToDo
History
Clean MAF Sensor
R/R Fuel Filter
R/R Oil Filter
