I have some aluminum on which I need to make some miter joints. What I am cutting is about 8" wide and has several bends and channels (think guttering, but more flat). If I use my 10" chop saw, what type of blade should I buy/use? I know for vinyl siding they recommend mounting the blade backwards. Any trick like that needed here? Should I just stick to my tin snips? Since I am doing the project myself, how much of the savings should I spend on Oil?
Thanks!
Thanks!
