Best water pump for 3800 v6
What is best water pump brand for a 3800 v6 car?
Nothing wrong with the GMB water pump. GMB says to turn it by hand after filling the coolant before installing the belt and starting the car for the first time after installing it :)
If you feel like spending the money, the OE GM water pump is still available.
Whatever water pump you get, don't use the gasket that comes with it. Get a Fel-Pro gasket. You should also replace the bolts. Dorman has a set of bolts for the WP.
To drain the coolant from the knock sensors like GM says, you will need an oxygen sensor socket like this. Make sure the engine is cold, like first thing in the morning cold, or else the knock sensors won't come off without damaging them. They use a tapered thread with some loctite on the threads.
If you have plastic coolant elbows on the tensioner / alternator / heater hose bracket, they will almost certainly break when you disassemble, so have replacements ready.
Also this. Get aftermarket metal elbows, if they haven't already been replaced by now. The O-rings that come on the metal elbows suck, so you will have to swap them with OE O-rings.
And some of the water pump bolts are wet on the inside ends, so you will need to apply sealant to the threads. Don't use sealant on the gasket though.
All I know from me and all my friends that we all owned a 90's GM with that 3800. When putting that new water pump one back on ( or even taking it off , been so long I can't remember but you got that one long aluminum bolt and I hope you don't hear like me and and ALL my buddies got that "PLINK" sound as the long bolt snaps in half and then you get that terrible feeling ol crap what did I just do and what do I do now?
We all found out that GM will actually run fine minus that long bolt... LOL
Mine is a Gen III (2006) and all the bolts are steel. One is behind the power steering pump pulley but there is an access hole thoughtfully provided. Overall it was an uncomplicated R&R.
I second the GMP pumps as an excellent option
I had older gen II 3800's, but had no issues with whichever Duralast pumps that were sold at Autozone at the time. Granted I only put on a few tens of thousands of miles after that before getting rid of those vehicles.
I had no issues getting the bolts out, nor reusing them or using the included gasket. Don't recall using sealant either - but it's been a while, it's possible I did.
Ahh I had a Series III 3800 for 10 years. I remember doing the water pump. To be honest I just used an AC Delco Pump & Gasket.
Looking at old Dodge Magnum applications (3.9/5.2/5.9) it looks like O'Reilly's house brand MasterPro is actually GMB.
Ironically I've had their "better" Murray leak profusely in under 8k miles, so in the future for quick availability I'll be at least handling the MasterPro stuff. In the application above the pics actually show "GMB" cast into the body
Useless trivia.....
Useless trivia.....
I like that kind of trivia!
Oem. Ac Delco
GM Genuine, sure. Basic AC Delco, no.
Anyway for shizzles & gizzles I called up the Masterpro pump for an '07 LaCrosse with 3.8. Here again looks like GMB. Retail $42, commercial $36. @GMBoy
Useless trivia.....
I used a GMB about 9 years ago on my old 3.9l Dakota, I put about 70k miles on it and my buddy owns the truck now, still works fine.
I stay away from at all cost, Gates. Had to replace the last one on my kids Mazda Protégé in less than 6k miles. You have to remove the timing belt to replace it, never again. Such a pain
  • Helpful
Reactions: D60
