GM crankseal 3800 v6 replacement question
Today I put crankshaft seal on my 2001 Pontiac grandprix with gm 12582313. The crank shaft seal looked different than the factory replacement. The seal didn't go all the way in, so I pressed as much as could it but didn't go all the way in. Is this normal? Does the new crank seal doesn't go all the way in? Or did i do a bad job? Does anyone have experience in changing the crank seal in 3800 v6 engine?
  • Like
Reactions: Arc
Did you use a driver/seal tool?
From the FSM
I ended up with a leak the front seal popped out had to use a driver and tap it all the way in.
