Originally posted by Norm Olt:
I don't know about you guys, but I have NEVER had a vehicle "overheat in an unsafe neighborhood or highway"... Or overheat ANYWHERE?
Of course, it may have something to do with the fact that I have always maintained the cooling system on every vehicle, two or four wheeled, that I have ever owned.
This includes replacing hoses and belts BEFORE they break or leak (you put the old belts and hoses in the trunk after you clean & inspect them as spares), changing antifreeze on a regular basis, looking for worn or leaking seals, radiators, etc. as a matter of routine maintenance.
Of course emergencies will happen, occasionally, but one can do a lot to make sure that one is prepared.
I can't imagine how any quality oil, dino or synthetic, if maintained in proper quantities & changed on any regular basis, would somehow result in an overheating situation at the beginning or at the end of its OCI.
A water pump can go South, a belt can break: that's what idiot lights and guages are for, IMHO.
Cheers!
p.s. I'd go with the 5W-20 Havoline @ $1.18: actually, in Tampa, FL I would personally use a 5W-30, but that's just me...
