I've got a 2006 Ford Escape with the 3.0 EcoBoost engine. It weeps oil, as a lot of them do. I've been using Castrol 5W-20 High Mileage synthetic blend, and don't have to add oil between oil changes, but the stain on the driveway annoys me. I see 5W-20 conventional oil at Meijer and Farm and Fleet. Might conventional oil reduce the leaking?
Try snugging oil pan and valve cover bolts to
proper torque. Sometimes that helps. It can't hurt. Also, try to identify the source of leak.
Synthetic oil leaks most, conventional oil least, synthetic blend is in between. 5w30 leaks less that 5w20. High Mileage (HM) oils are designed to leak less. You can combine those traits to minimize leaking. For examples of oils that combine those traits.
I think you'd do best with a High Mileage 5w30 oil that's a Blend or Conventional.
I suggest 5w30 Valvoline HM Maxlife Blend (red bottle), or 5w30 Oreilly HM Conventional, or any brand of High Mileage 5w30 conventional.
Personally, I'm going to switch my slightly leaking/dripping Buick from High Mileage 5w30 Maxlife Synthetic to High Mileage 5w30 Maxlife Blend. I'm confident that Blend will reduce my drip, but don't know if it'll completely stop it.
Why don't I just switch my car directly to 5w30 Oreilly HM Conventional? Because a Blend oil lubricates better than Conv. However, realistically that shouldn't a concern for my car. Still, I want the best lubrication I can have without leaking.
After changing to one of ^ those oils... It might take some time and 300-500 miles for your engine to stop leaking. If it still leaks after 500 miles, then you need to do more.
If none of the above oils stop the leak, then I'd try adding Blue Devil Oil Stop Leak, or some other good brand of oil stop leak. Other people can recommend other good stop leak products too.
Warning... Not all brands of oil stop leak products are good. For examples of ones to avoid... I would avoid Lucas and STP oil conditioners and/or stop leak products.
Blue Devil Oil Stop Leak should stop a minor leak within 300-500 miles. If it's still leaking after 500, then it's not going to stop the leak.
If it still leaks after trying the above things... Then you need to locate the leak and replace seal(s) or oring(s) on whatever is leaking.
