Best Synthetic for best price.
LOL I'n thay case I would use a synthetic but in a 2.0L sunbird I redline at 6,000RPM.
Rick, I've seen a few oil analysis results with dino oils, including GTX, where the owner drag races their car and pushes it to the redline on a daily basis, and even at 3k the oil still looks great.
I ran a 3300 mile interval on Maxlife in my 95 Firebird for instance, putting quite a few quarter mile runs on it plus full throttle redline blasts 4-5 times per day, and after that the oil analysis still showed the oil could've gone longer, 5-6k perhaps.
I guess I should be ok with a dino 10w30 in the summer and 5w30 synthetic in the winter.
Originally posted by rick:
Would I be ok If I were to use Castrol GTX as an eg Then every 3-4 oil changes use a bottle of Rislone engine cleaner for 1k miles.
Would I still be ok from sludge build up.
I'd change by oil every 2k Miles
If you're changing it that often the oil will probably takes years and years before the engine got dirty. If you're worried though, you might want to buy a bottle of Auto-rx and run a 3oz maintenance dose with each oil change to keep things clean for sure. So a 12oz bottle of the stuff would last you for 4 oil changes.
Yes, that sounds good. Depending on the car you might even want 10w40 in the summer. I've seen good oil analysis results with GTX 10w40 in an LS1 Firebird.
Ya but the auto-rx is very expense for my taste.
What if I just used a bit of rislone once in a while not the whole bottle maby a quarter of it?
I'm not quite confident in that Rislone stuff to recommend it actually. I'm not saying it's bad, just that it's unproven on here.
I guess I'll just stick to frequent oil changes for now, I usually wait when walmark put oil on sale. Usualy down to 5 dollars for jug.
Yep, I snapped up two of those GTX jugs for my sister's car! One was $5.96 then they marked it down to $5.00! But the sale is over.
I've been trying to get this across to people for a while now, if you're gonna do 3k changes all the time, synthetics are of very little benefit to you (except in extreme cold)
Ok so from everyone has sayed with 3k changes synthetics are of now use, but what about for someone who does 3k changes but runs there engine hard from time to time, eg high rpm?
I have a 2.0L sunbird is 10W-40 safe to use in it during the summer?
If your mileage is higher, chances are good that this engine will like the 10w40 better in the summer than 10w30.
Speaking of Sunbirds, my neighbor has a V6 sunbird (not sure if it's the 2.8 or 3.1) that is approaching 400,000km now! (250k)
[ February 03, 2003, 05:24 AM: Message edited by: Patman ]
Rick. You can run a few ounces of Schaeffer’s (Commentary: pricks) Neutra through the crankcase every few changes. Will only cost you about a buck. People on this board have determined that it is effective.
Originally posted by S2000driver:
Originally posted by buster:
In S2000Driver's case I'd use Amsoil 0w30 or M1 5w30.
Believe it or not, they recommend 10W30
for the S2000. That's OK with me, I drive something else below freezing anyway.
10W30 is surprising in a Honda. I figured it would be 5W30. -Joe
I have the feeling they did it to maintain high viscosity over time... since 10W30 in theory has better hot viscosity stability than 5W30.
