If you're changing it that often the oil will probably takes years and years before the engine got dirty. If you're worried though, you might want to buy a bottle of Auto-rx and run a 3oz maintenance dose with each oil change to keep things clean for sure. So a 12oz bottle of the stuff would last you for 4 oil changes.quote:
Originally posted by rick:
Would I be ok If I were to use Castrol GTX as an eg Then every 3-4 oil changes use a bottle of Rislone engine cleaner for 1k miles.
Would I still be ok from sludge build up.
I'd change by oil every 2k Miles
Yes, that sounds good. Depending on the car you might even want 10w40 in the summer. I've seen good oil analysis results with GTX 10w40 in an LS1 Firebird.quote:
I guess I should be ok with a dino 10W-30 in the summer and 5W-30 synthetic in the winter.
I'm not quite confident in that Rislone stuff to recommend it actually. I'm not saying it's bad, just that it's unproven on here.quote:
Ya but the auto-rx is very expense for my taste.
What if I just used a bit of rislone once in a while not the whole bottle maby a quarter of it?
Yep, I snapped up two of those GTX jugs for my sister's car! One was $5.96 then they marked it down to $5.00! But the sale is over.quote:
I guess I'll just stick to frequent oil changes for now, I usually wait when walmark put oil on sale. Usualy down to 5 dollars for jug.
Believe it or not, they recommend 10W30quote:
Originally posted by buster:
In S2000Driver's case I'd use Amsoil 0w-30 or M1 5w-30.![]()
If your mileage is higher, chances are good that this engine will like the 10w40 better in the summer than 10w30.quote:
I have a 2.0L sunbird is 10W-40 safe to use in it during the summer?
10W30 is surprising in a Honda. I figured it would be 5W30. -Joequote:
for the S2000. That's OK with me, I drive something else below freezing anyway.![]()
