The 1992 300E manual is quite similar in its wording, stating that for adding water, the water must be of sufficient quality, and that it must be “treated” if it is not.
Here‘s the screenshot.
I've answered that twice in this thread. Yes it does. Water has a certain solubility for metal ions, and since distilled and deionized water has no metal ions then it will dissolve metals. But that solubility is finite and in a closed system such as a cooling system the amount of metal it will dissolve is in the micrograms. This behavior is not limited to distilled or deionized water however, some water has quite a bit of dissolved iron but perhaps no aluminum. That water will dissolve exactly as much aluminum as will deionized or distilled water.I posted this in the hope of finding out, not to go toe to toe with someone about it. I use distilled water in all my cars. Some how this question about the actual chemistry is elusive. Just want to know- Does distilled/deionized water leach metals out of coolant systems?
And this makes complete sense. Because the consumer may not know specifics about their water supply then the easiest and clearest course of action is to used deionized or distilled water.So, water added to a Mercedes cooling system is not required to be distilled, as the Bevo sheet already said, and I already posted, but it must have no more than a certain concentration of dissolved salts. No more than.
I am still looking for a document, from a manufacturer, that says it must have a minimum of XX concentration of calcium, etc, that drinking water would have.
In other words, a prohibition on distilled.
Let me know if you can find that “Mercedes Tech article”
Astro- what do you need to be comfortable? He references a M-B tech article as I do. Two independent sources. Good enough for me. I'm satisfied. I'm not about to scour the i-net to provide additional info. Its not worth it to me to prove you right or wrong. If you feel so strongly about this "tempest in a teapot" - go for it. Regarding authors experience or credentials, the same can be said here for the other posters.I’m interested - but you’re asking me to accept, as fact, an opinion, a self-admitted controversial opinion, relayed from the author of an article in a car magazine, from 12 years ago, that refers to a tech publication that no one seems to be able to find?
Though I accept your quote as genuine, and believe that you found it as is, and while I appreciate the work, it‘s lacking the manufacturer recommendation I was seeking. I don’t know the author’s experience or credentials, so, it remains opinion.
If we could find the elusive “Mercedes tech publication” from 20-25 years prior to 2009, to which the author refers, and to which you’ve referred, that would be a good start.
If we could find something current, from a manufacturer, recommending against the use of distilled water, then, that would be even better.
I‘m willing to read, to listen, to change my mind, but it has to be because the facts are there.
Really K- you are complementing yourself- I simply don’t care about your implied idea. Just being sucked into your game of endless posts. Over something no one cares about…You have one vague reference from a third-party to a statement that isn’t even verified. And you’re asking whom you think people believe?
Perhaps you could spend some time showing that my answers to you are incorrect. You seem to be invested in that idea.
That’s just bizarre. You make the posts asking and asking, and when answered you get snarky… again. Well at least others in this thread can read what’s posted and learn.Really K- you are complementing yourself- I simply don’t care about your implied idea. Just being sucked into your game of endless posts. Over something no one cares about…
Bring on the vote!!
Hi everyone, I helped put that article together. I would be glad to help answer coolant questions you guys have...let me know!Reading that link you posted, on page 3 clearly says that OAT is the best coolant out of conventional/hybrid-hoat/oat. That is quite interesting.
