Originally Posted By: Kuato
IMHO, AutoRX is a "slow cleaning" product, made of esters. It is no where near as aggressive as many of the other products.
True enough, and it's what they say on their website; their point is that through slow cleaning you will not get the "chunks" that can clog oil passages and the junk removed by the slower cleaning process will get caught in the filter.
There's a couple testimonials on the site where people's oil consumption has gone away...at only $24 for a bottle it is probably worth a try, before doing an expensive ring job.
Originally Posted By: chevyboy14
I have heard of that stuff where would I get auto rx ... ?
Auto RX Right here.
And that would be relevant if we were dealing with sludge or deposits in the engine that we were trying to slowly remove. However, that isn't the case here. It is a specific symptom that stems from low-tension rings and varnish. Even if we remove all the varnish, as indicated by the poster above you, there is no guarantee that the consumption will completely go away. This is the case when the rings lose their tension.
