Best oil for my 1.4T Trax?
Suffolk County, NY
I've been using mostly Castrol Edge (black bottle, non-EP) along with strictly AC Delco filters *UFI cap 🙄*. I've ran it strictly following the OLM. However, I remember someone a while ago on BITOG running some used oil analysis and saying that some oils looked on the edge of shearing at around 20%. Do you guys have any suggestions on oil brands and if I should still follow the OLM? Thanks. I don't mind spending a little more.
Edge of shearing? I don't know if I've ever seen a passenger car cause actual mechanical shear in an oil on here, if the UOA were from Blackstone then there is no way to reliably discriminate a viscosity deviation between fuel dilution and mechanical shear. They also have shown difficulty in accurately measuring viscosity. Shear is one of those terms that's thrown around a lot and the vast majority of time it is fuel dilution or inaccurate viscosity and/or flash point measurement.
So having said that I'd use any oil that carries the specification or license listed in your owner's manual. As noted above a dexos licensed oil is a good choice.
Here’s a used oil analysis from my wife’s 1.4T in her Buick. The oil was (claimed to be) bulk AC Delco 5w30 Dexos from the dealer invoice who did the last oil change. I change it for her every 5,000 miles (about 30-40% OLM) on these high strung turbos. They’re tough on oil.
https://bobistheoilguy.com/forums/t...turbo-5-243-miles-ac-delco-dexos-5w30.337517/
Another option would be Pennzoil Platinum Euro L 5w30. It is at the higher end of the cst for a 30w, almost a 40w and held up better than Castrol and Mobil 1 in my kids Volvo C30 both 5w30. The others would be use about 1 to 1.5qts between 7k mile oci's and the Euro L was right at full everytime. I personally would ignore the olm and just change whatever you end up running at 5k oci's. Good luck
Quaker State Synthetic at Wal Mart. That’s my thought
