Hey guys,
Long time reader but first time poster. I need some advise on what oil to run in my essentially bran new Defender 110 that was fully restored including and most importantly the engine. The engine is a typical Land Rover V8 flat tappet style engine. Mine has a slightly hotter cam and was ported and polished. It's a wonderful engine and runs incredibly smooth. It is time for it to have it's first oil change at 3000 miles. I think right now it has 10-30 Castrol GTX which is what some service station gave it before being sent to me. My goal is to give it the best oil for the rest of its life. Cost is of no concern so please feel free to recommend the best.
Details:
Factory Recommendation
I live in Napa Valley, CA. It sees a range of temperatures of lets say 15 F - 110 F but since I use the truck for overland travel it can see more extremes then this on trips that I take a couple times a year.
Driving Style:
I really take care of gear and am meticulous about maintenance. However, I do use my truck and it works hard sometimes pulling a trailer up a steep hill. I do a lot of off roading in dusty environment. I do have a raised air intake and change my air filter very frequently.
Driving Habits:
I live where I work so a lot of my driving (the Defender is my work truck on the farm) is short little trips of just a couple minutes. Sadly I don't see a full warm up every time I drive it. I do however make some very long trips occasionally (all day driving) of say once a quarter. I make it into the city where I can see some stop and go traffic but otherwise my area isn't that congested. I think the most important detail here are the many short trips around the farm I do all day, most days.
Known Problems:
The truck, being very new, has no known problems. The cooling system is very robust so the truck operates at around 180 F (water temp) no matter what I do. And it does have a very accurate and calibrated VDO temp gauge that isn't "slow to read reality".
My ignorant opinion:
I've been reading and reading and reading on this sight all about what is the best oil...here is what I came up with. In my narrow-minded opinion what I figured is the theoretical best oil for my kind of engine is Redline 0W-40. Why? The 0W, because I assumed that with my frequent cold starts I would benefit from an oil that flows as good as possible at start that would help get things lubricated quicker. The 40W because it is within the recommended range of my Defender and is also a pinch thicker which helps keep the leaks a little more in control because these engines tend to leak prematurely from the rear main seal. Why RedLine? Well this is a little more propaganda then anything, but because it supposedly has the higher elements needed for these older tech engines. It also has above a 3.5 HTHS which I heard is needed for these engines. I heard that the Mobile 1 0W-40 is more formulated for the newer stuff and doesn't have the "good old stuff".
So what is an experts recommendation? I really want the best for this engine given my diverse requirements.
Thank you in advanced.
Details:
Driving Style:
Driving Habits:
Known Problems:
