Originally Posted By: Exit32
I'm in the process of restoring a 1966 Pontiac GTO that is equipped with the optional 389-cubic-inch, 360-horsepower, Tri-Power engine.
This engine was rebuilt by a previous owner, and the cylinder bores, rings, and bearings are in good condition. However, the camshaft is incorrect for a Tri-Power engine, so I am installing the appropriate GM 9779068 camshaft with new hydraulic lifters.
I plan to use Crane Cams Super Moly Assembly Lube to coat all the cam lobes and lifter surfaces before assembly. I will also spin the oil pump with an electric drill to build oil pressure before starting the engine, and I know enough to run the engine at a fast idle for the first 20-30 minutes to make sure the cam is getting plenty of oil during break-in.
My question for those in the know here is, what motor oil would you recommend for the initial break-in period and what motor oil is recommended when it's time to drive this beauty to car shows and cruise nights? Also, do I need a ZDDP additive like ZDDPlus because this is a flat-tappet engine?
I'm thinking maybe Rotella 10w-30 or even Rotella T5 10w-30 would be appropriate.
FWIW, here are the specs for the new GM 9779068 camshaft:
- Intake duration @ .050" lift: 212
- Exhaust duration @ .050" lift: 225
- Intake lift w/ stock 1.5 ratio rockers: 0.408"
- Exhaust lift w/ stock 1.5 ratio rockers: 0.407"
Your opinions and guidance are much appreciated!
JOE GIBBS BREAK IN OIL!! for about 1k then T5 after that
