Best Oil Filter from Rock Auto
I’m considering purchasing oil filters in bulk since it’s more cost-effective. With all the recent mergers in the industry, I’m unsure which brands are still reputable. I’m leaning toward WIX but would appreciate some additional opinions. I’ve attached a screenshot of the oil filters available on Rock Auto, and I’m looking for insights on the best filter to use for my 3.8 V6 engine.
Might want to look at the filter C&P section here, several of these have been recently autopsied.
I like the high(er) level filters from many brands.
Which higher level filter is better than others form my applications
and which are readily available are the ones I try to stick with.
I had an issue with Champ XL filters where label on the filter and box they came in stated one model, but ink stamp on the filter stated another and correct model. Check the filters when you get them, if you wait too long you won't be able to return them.
Wix and Bosch may have closed or semi closed louvers.
Double check Mahle filter model, I think you may use OC494 or OC90 as well. If filter isn't made in Austria it's more or less junk too.
