- Joined
- Feb 13, 2021
- Messages
- 3
I use inox MX6 grease. It contains PTFE. Have heard good and bad on that part though. Curious to hear what others have to say regarding the PTFE.
Super Lube brand, Synthetic Grease, should meet your criteria.Usually, when it's food grade and certified NSF H1 it's certified non-toxic in cases of accidental food contact for the food industry making it less toxic/harmful for humans. I'd like to avoid toxic chemicals from automotive greases/oils. I want it to be safe or "safer" for skin contact when I apply it.
Mobil website: "These NSF H1 multipurpose grease products are rated for incidental contact with food in applications where contact is unavoidable. They are safe for human consumption in diminutive quantities and are often used on equipment such as conveyor belts, pumps, and mixers that are in close proximity to food production."
Are there any greases out there that are certified and registered non-toxic that are not specifically made for the food industry? I know of Boretech grease and Slip2000 EWG but they are very expensive for the little amount you get...
MobilGrease FM 101: $16 for 14oz
Lubriplate SLF-0: $28 for 14oz
Boretech grease - $15.49 for 10cc of grease.
Slip2000 EWG - $13.70 for 1.5oz. $84.93 for 16oz.
Canola oil is what fireclean uses.Usually, when it's food grade and certified NSF H1 it's certified non-toxic in cases of accidental food contact for the food industry making it less toxic/harmful for humans. I'd like to avoid toxic chemicals from automotive greases/oils. I want it to be safe or "safer" for skin contact when I apply it.
*Look for Super Lube Synthetic Grease brand grease - it’s food grade , non - toxic and a great synthetuc grease for firearms offering great wear prevention , has a wide temp range , doesn’t break down and stays put where you apply it . Harbor Freight carries 3 oz. tubes cheap ($7.64 now on sale !) I also order on line from Amazon and have ordered from Home Depot and had it shipped to store for pick up . Lastly , you can get larger tubes and tubs of Super Lube Grease for a FAR better deal than typical firearm specific greases !Usually, when it's food grade and certified NSF H1 it's certified non-toxic in cases of accidental food contact for the food industry making it less toxic/harmful for humans. I'd like to avoid toxic chemicals from automotive greases/oils. I want it to be safe or "safer" for skin contact when I apply it.
Super lube grease is what I use. Super Lube oil for hard to reach places. Then wipe the outside down with some break free clp. The grease is perfect for semi auto rails*Look for Super Lube Synthetic Grease brand grease - it’s food grade , non - toxic and a great synthetuc grease for firearms offering great wear prevention , has a wide temp range , doesn’t break down and stays put where you apply it . Harbor Freight carries 3 oz. tubes cheap ($7.64 now on sale !) I also order on line from Amazon and have ordered from Home Depot and had it shipped to store for pick up . Lastly , you can get larger tubes and tubs of Super Lube Grease for a FAR better deal than typical firearm specific greases !
Read about “Eezox” for exterior protection .Super lube grease is what I use. Super Lube oil for hard to reach places. Then wipe the outside down with some break free clp. The grease is perfect for semi auto rails
Works well, but is it food safe?
