quote:
Originally posted by haley10:
Can you post some of these statistics?? I am using M1 10W-30, but I have an open mind.
I've poured my oil at -10F and a 0W and I can't tell a difference, so I'm not sure my pump or engine can.
I decided to run this 10W-30 year round because it seems totally fluid at my temps. What am I missing?
If you look in the very firsp post in this topic, there are a couple of links for some data. The little investigation I did a couple of years ago over the phone and e-mail when I was investigating the benefits of using Pennzoil's Penzane solid lubricant on our control moment gyros on a Mars spacecraft. It started with a conversation with a Pennzoil engineer, and he mentioned that "oh, by the way, Penzane is in our synthetic motor oil, but I'm not sure it really does much good there, since start-up wear is really the killer for cars". Incidentally, the Mars spacecraft did end up using Penzane due to its performance in the vacuum of space. Its true Pennzoil's marketers was putting a picture of a spacecraft on their synthetic oil, and there was indeed small, trace amounts of Penzane, but its mostly marketing lies that it does much good in cars. For the Mars spacecraft it was great, though. Anyway, I went off on a tangent and started calling/e-mailing Mobil, a Canadian oil company, 76, and a couple of MIT engineers, given that I was a bit obsessive about the subject, and some interesting conversations showed up such as "A fleet of trucks was analyzed specifically for start-up wear and it was found that cranking accounting for 60%, in one case, of the lifetime wear on an engine". Other similar conversations ensued with whoever would talk to me, and the conclusions were all the same, STARTUP WEAR so dominates the picture, that as long as you have oil pressure you're engine is not wearing much. Therefore, most of the game becomes getting oil pressure as fast as you can. Period. Other people on this post will try to tell you other things, but as long as you have a good basic oil that flows well when cool/cold, you're fine. This post did change my mind about Chevron Delo Synthetic, though, as now I think German Castrol 0w-30 will cut your wear down more than anything else because it continues to flow when cold.
