Best high mileage oil for leaks
Best High Mileage oil Mobil 1 High Mileage
Best budget High Mileage oil Valvoline MaxLife red bottle.
Mobil 1 High Mileage stopped both rear main leaks in two Jeep 4.0s, which should be impossible as the engines are designed to leak.
I switched away from Mobil 1 High Mileage due to the modern zinK impoverishment, and the leaks started up again. YMMV
I watched a youtube oil change video about an oil change for a 2003 Toyota Corolla, and the guy said Valvoline makes a more stronger high mileage oil with a heavier dose of seal swellers, but it's only available to order from Valvoline's website. I haven't looked into it further, but it might be worth a try.
Barrs leak oil stop leak works really well. It's just a seal conditioner. I've used it in most of my cars, some for 7+ years.
Aside from that, the non synthetic maxlife was the only High Mileage oil I've thought was effective
Are you referring to the Valvoline HM+ oil? Their description touts seal conditioners and moly, so this may be closer to the old formula from 20+ years ago (?)
