Originally Posted By: dnewton3
As well, your consumption may be an issue of poor ring/wall fit. I had an issue with my older Vulcan v-6 due to an overheating event. I found my rings badly coked. After an ARX treatment, the rings were liberated and the compression (and ring sealing) were massively enhanced. Have you considered an ARX treatment or two to see if this "need heavy oil" issue can be resolved?
I am guessing that the most likely reason for the oil consumption in my case is the valve-stem oil seals. I can replace them without removing the cylinder head but it's a repair that I've never done and there is some risk that the valves can fall into the engine. I've adjusted the valves many times in the past but have never removed the rocker arm and valve springs. 1 qt / 1000 miles consumption is manageable for me and the car passes the California dyno emission tests; so, I probably won't get myself into this repair at the moment.
