dnewton3
Staff member
I see the choice of oil vis as a preference, and not a "must do, must not do" situation.
I choose 10w30 HDEO beuuase it can get down below zero deg F occasionally where I'm at, and will regularly get below +10. I like the quicker spin-up and oil pressure with the 10w30. The 10w30 is an approved (although not preferred) vis by GM for my Dmax. I have run 15w40 conventional and 10w30 conventional, and I like the 10w30.
As for the 10w30 consumption, I didn't find it all that much worse than 15w40. Comparing two similar summer trips, one with each vis, I say perhaps a few tenths of a quart difference over an entire year! I generally consume around 2 qrts annually. In fact, because that represents the upper and lower portion of the range on the dipstick, I rarely even bother with a top off. I OCI in fall, when the heavy loads of summer RVing are over. I see zero consumption all winter. I only see consumption of oil after a heavy season on towing. One reason I don't add oil during my annual OCI is because when I do a used oil analysis, I want to see how the initial host oil held up, with no help from a top-off. I don't see this whole 10w30 versus 15w40 debate reasonably teetering on the consumption issue; the difference is grossly exaggerated in most circumstances. After 7k miles (half of which are heavy towing for me) it might mean .2 or .3 of a quart differnce. Big whoop ...
And what of "consumption"? As long as it's reasonable (which I condsider mine to be) then it provides one an opportunity to replenish the oil and therefore the add pack. I never see "normal" consumption as a bad thing. Hence the term "normal".
My used oil analysis have consistently shown that my Dmax engine (all others as well) is really easy on oil, and do quite well regardless of brand or grade of oil used, AS LONG AS IT'S A PROPERLY QUALIFIED OIL TO THE OEM SPECS. That may or may not be true for the engines in the OPs quest.
We can be generalists here, and make some assumptions. And when people like the OP ask questions that are not well defined, we're stuck with offering answers that are somewhat generic. If he wanted to discuss heavy 80,000 pound OTRs, he probably would have brought it up.
For his applications, and desire to have one common oil, I see a 10w30 HDEO as a great all-around performer, PRESUMING that it's a qualified and spec'd fluid for each vehicle. If not, then my suggestion is null and void. What is MOST important is how he values convenience versus specific application. Surely a 10w30 will do well in all the vehicles he mentions. However, I'd be the first to agree that perhaps a 15w40 for diesels and 5w30 for the gassers would be more optimum for the engines, but only he can decide which is of more value to him, not us. 10w30 will certainly work well, but it may not work "as well" as something more specific. This is exactly why I use 10w30 in a lot of my equipment; commonization of fluids means less inventory and easier OCIs, etc.
BTW - when one runs the risk of "running out of oil due to increased consumption by using a lower viscosity...", it is not he fault of the lube. IT'S THE FAULT OF THE OPERATOR! It is completely unfair, and border-line silly, to blame a lube for a lack of proper maintenance. And maintaining fluid level is part of a proper maintenance plan. This is a pet-peeve of mine.
Want to know how to put this all to bed? used oil analysis, folks, used oil analysis. My suggestion is for 10w30 all the way around. Try it. Even if it's not perfectly suited, it's not like the engines are going to self-destruct after one OCI ...
