Best fully synthetic 5W30 engine oil
Perth, Western Australia.
I was thinking of using a fully synthetic 5W30 engine oil in a 1.4litre TSI turbo-charge VW petrol engine that normally requires a VW 504.000 approved oil (to protect the catalytic convertor apparently). Royal Purple HPS is not VW 504.000 approved but they assure me that it exceeds VW 504.000 and will be fine. Is there anything else that is better that I should be considering?
Mobil 1 or castrol full synthetic are great. If you go with an oil that meets a dexos requirement you’ll be fine. I use dexos as an example because of its high rating.
Mobil 1 ESP. Excellent choice that meets 504/507 in either 0w30 or 5w30.
The 504/507 spec goes well beyond after-treat compatibility and I would absolutely seek out an oil that is approved.
No, no, no, no.
in 5W30 flavor, you will not find better oils than those approved for VW504.00/507.00. STICK TO THAT!
It is not catalytic converter. All oils are made to protect catalytic converter. It is numerous other stuff.
Do not fall for "meets and exceeds" garbage!
If by "Full Synthetic" you mean PAO, i believe Ravenol may be your choice. I don't know the HPS levels but Mobil 1 ESP 5w30 has very little....
But as others have mentioned, ESP is a great oil that has the approvals. I'm not sure if HPS just says "meets or exceeds" or goes further by having "approved" on the bottle. The decision as to what your comfortable with is yours.
I know this site can be confusing at times as many of us have asserted that given the choice between two approved oils, we'd take the one with more PAO content. But in all actuality we don't know if that alone makes for a better finished product.
There is zero chance that HPS meets or exceeds 504/507.
Only SDS I could find for the HPS 5w30 is from 2018, but that may still be current. Shows 10-25% PAO, rest is Group III:
Whereas the Mobil product appears to be 30-40% GTL, per the above MSDS from wemay, a dash (1-5%) of PAO and whatever the rest of the base blend is doesn't have to be shown on an MSDS, so perhaps it is one of the Esterex products.
