After I discovered this web site I switched from Valvoline oil to Chevron. My previous car ran great with the Chevron oil. But in my new car it does not seem to make such a difference.
Best conventional motor oils I have tried that actually seemed to make a difference in how smooth the engine ran (just subjective opinion, I know) were the Chevron in my previous car, Schaeffer's oil (a blend), Mystik. and although I stopped using Valvoline the Valvoline MaxLife seemed to run great in my previous car. I tried the MaxLife to stop a small seal leak. It did not stop the seal leak but the engine (subjective opinion) seemed to run silky smooth. Auto-RX seemed to stop the seal leak. I think Valvoline does have a winner in the MaxLife, regardless what their other oils may be like. Pennzoil and Castrol conventional oils are good too. I think the new Motorcraft oils (made by Conoco) are really good and the new Mobil Drive Clean blends were developed fairly recently.
Just my guess, but the Schaeffer's blend is hard to beat. It does cost about $3.00 a quart, but it is cheaper then Mobil 1 unless you can get Mobil 1 on sale. You probably will not be able to find Schaeffer's locally and you would have to order it.
