I’ve actually installed a set of Toyota service pads “dry” - no lube on the ears. I did apply a thin film of Permatex Silicone Extreme to the underside of the abutment clips. Else, it was Molykote AS-880N between the shims and pad backing plate and Toyota Rubber Grease on the slide pins. The red Toyota grease is a glycol-based grease, think Sil-Glyde in consistency, but with a different base oil vs. Sil-Glyde’s castor oil base.South Main Auto on YT doesnt apply anything to those ears. Just cleans the guideways. Makes sense to me because if water doesnt wash it away first, road grit will be attracted and defeat the whole purpose of using grease anyway.
