Our 2022 Rav4 Hybrid has about 45k kms (28k miles) on it, and we have owned it from new. It sees very harsh winter climate with lots of snow, moisture and salt. I took the brakes apart this weekend to service them and the front brakes were very unevenly worn. The front caliper pins were seized up, despite the fact Toyota serviced them about 1 year ago. The inboard pads are probably about 75-80% worn, while the outboard pads are only about 10% worn. So I will likely have to replace the pads sooner than later, which is very disappointing life - the shortest brake life I have ever had on any car I have owned.
The pins freed up fairly easily and are lubed, but the were locked up solid enough that the caliper wouldn't slide. So I am not really sure why they seized. The rear brakes had the "ears" seized up in the stainless slider clips and appeared to be dragging a bit. So they too are wearing prematurely, although at least evenly.
What are those in the northern climates doing to service their brakes and keep them from seizing? Do I need to start servicing every six months? That seems ridiculous on a modern car. These modern brakes seem worse for seizing to me than say the old cheap single piston sliders used on my old GM RWD cars. It's disappointing to pay big dollars for a new vehicle, have the dealer service the brakes and still have these issues.
