Two Part Question:
I'm in the early stages of owning my 2016 Honda Civic 1.5 L turbo motor. I'm preparing to find some fuel dilution when it comes to do a used oil analysis which may come around 10k kilometres give or take. I will likely pull a sample 1/2 way through the run and send it out for testing.
The latest VOA's of Honda's 0w-20 don't look like anything special, I'd be interested in the Mazda 0w-20 oil but it is geared to being thin for efficiency reasons and is thinner than the Honda fluid AFAIK. My personal preference would be to run Red Line's 0w-20, it looks to be very well built, but my Honda dealer won't likely install it if supplied to them and I've got a 5 year power train warranty that I need to maintain. I might explore asking them but I think that I know the answer.
My other choice would be between Amsoil signature series, Penzoil Ultra, or Mobil1.
Secondly, Honda's manual seems to indicate that most of the break-in is done by 600 miles, but the dealer always says to keep the factory oil until 5,000 miles +. I know two race engine builders in my area. One of them tells me that break-in of the rings is mostly done in the first 100 miles. The other builder breaks in his motors with a 1/2 dozen controlled runs on his engine dyno and that is it. Any suggestions how long I should leave the factory fill in this engine ?
Thanks for any replies.
Hi JS2000 - We'd love to offer you the opportunity to try Pennzoil Ultra Platinum through our Used Oil Analysis program. Through the program, we'd send you two samples of our motor oil along with testing supplies for Blackstone so you can compare the oil that's currently in your engine to Pennzoil Synthetics with results from an unbiased lab. If you're interested, please send us a private message for more details. Talk soon! - Gena & The Pennzoil Team [/quot
JS2000, the free oil us nice, but aware that Blackstone's fuel dilution measurement (based on flashpoint which is based on human observation)is imprecise at Best.
In my case, Blackstone estimated 1% dilution despite a 0w-20 viscosity of 6.2 (fresh = 8.7) after 2,300 miles. Under similar driving conditions/mileage with a viscosity of 7.0, Polaris, which uses more precise gas chromotography,determined fuel dilution of >5%. If you want to feel good, use Blackstone. If you want a more reliable fuel dilution reading, look elsewhere.
More great information, it's too bad there is such variation in testing methods.
I once had the oil in my Honda S2000 tested a couple years back from CAT who has a testing facility in my Province and I send it through the local CAT/ Toromont dealer. They measured fuel dilution at that time of 4%, so they must have had an accurate way of measuring it. I was glad for that as I was able to swap out my injectors immediately to correct the issue.
