My point was. Everything can be a factor. One factor can change everything.Well now that you mention it, that is an interesting topic. I had been running Fram Ultra filters exclusively but this last oil change I went to Wix XP. But, with that being said I would get 85psi oil pressure with the Fram filters within 1-2 seconds so I don't think that was the issue.
The sounds I'm attributing to piston slap is the sound I would get only when going out to start the car first thing in the morning. Not really concerned with it, I knew I would have it going into the build. I just found it interesting I can no longer hear it.
For a race motor and off-the-shelf oil, I’d prefer to use M1 ESP X3/X4 0W-40 as it has a higher HTHS (3.8) and holds its viscosity better. It’s the current Porsche oil.My car is a fully built "racing" motor with forged internals and looser tolerances than factory. The first thing I really noticed which is a rather big difference is that before with either Penzoil Ultra, Rotella, or VR1 in anywhere from 5W-40 to 10W-30 I would have rather loud cold start with piston slap until the motor got up to temperature some and the metal parts had time to expand.
For some reason with this Mobil 1 0W-40 EU formula my motor has no piston slap that I can hear at all and overall the motor is much more quiet. I did not expect this at all...
Oh and my Moroso oil pan leaks A LOT more with this Mobil 1 than the other brands. In it's defense though I am using a different nylon washer so maybe that is the problem. We will find out next oil change.
It could be valve train noise from excessive lifter leak down with the thinner oil.I would tend to agree with you, but I don't know how to explain it any differently.
Tappet clatter and piston slap almost sound the same.
I had a 95 F150 4wd Flareside and never experienced piston slap like my Honda. All I used in that truck was M1 10w30 and Pureone Filters. The only reason I sold it was because the frame was basically eaten out from all the rust. That engine was a beast, my dad also had 83 F100 and 87 F150 with it. They are actually quite hard to kill, the 83 actually went through 2 motors because the first one dumped too much gas and threw a rod, the 2nd one was basically used junk that someone put together and didn't last long either.Actually, it was available in the F series trucks for most of its run; from the 70s all the way until 1996 when that generation of F series trucks ceased.
The 300 six / 4.9L in F-150s never had a problem with improperly sized pistons, nor did it ever have forged parts.
My point was that ONLY the HD version of the 300 I-6 had forged internals, and that engine was ONLY put into the F600, F700, F800 chassis for dump trucks, box trucks, grain trucks, etc. The HD 300 I-6 was never fitted into an F150. By the time Ford was calling it by its metric name ("4.9L") that engine didn't have forged internals nor did it have piston size/bore issues. Whatever noise he's hearing likely isn't "piston slap".
Good question. You’re going to hear some valve train noise because of mechanical lifter clearance and that cannot be adjusted out.It's a B series Honda motor which is flat tappet. Maybe I should pop the valve cover to check valve lash.
Still, why would the noise go away with this oil?
I'm gonna stop you right there.
The only two things which generally cause "piston slap" are:
- improperly sized pistons to the bore
- forged pistons (which expand from warming up at a slow rate relative to the other components)
The F150 never had 4.9L engines which had either, in the 31 year run (1965 to 1996).
Whatever noise you're hearing, I seriously doubt it's "piston slap".
NOTE: The late 60s / early 70s did have some HD versions of the 300 six which did have forged internals, but those were only installed in very heavy service dump trucks, etc. Never into an F150.
That's not a bad idea but a lifter noise is more frequent and is a tap, tap, tap. Piston slap is sometimes mistaken as a rod knock. Hense, knock, knock, knock just not as "deep" sounding.It's a B series Honda motor which is flat tappet. Maybe I should pop the valve cover to check valve lash.
Autozone has a special where you can buy it with a filter for like 6 dollars a qt... but yes, it is more.It's almost 3 times as expensive and I change my oil roughly 2,000 miles.
I’d love to see some actual third party KRL test evidence of mechanical shear, considering this is oil carries a very high number of the most stringent manufacturer-specific certifications available, and several are European standards that require “remain in grade” as part of their requirements.m1 0w-40 tends to shear to a 30
Maybe next time don’t trust the internet as a substitute for your own reading comprehension. Go back and re-read both of dnewton3’s posts.
That would be interesting. I have zero doubt that it does considerably shear based on seeing UOAs of it for roughly 20 years, and taking fuel dilution into account. It has a large percentage of polymeric VIIs, so it is at a shear stability disadvantage. The stay-in-grade test must not be very tough to meet. I know this is blasphemy.I’d love to see some actual third party KRL test evidence of mechanical shear
Are you sure it’s mechanical shear, or is this more probably cases of people with known fuel-diluters “going up a grade” and happening to pick M1 0w40 because it’s the best balance of cost vs certifications?That would be interesting. I have zero doubt that it does considerably shear based on seeing UOAs of it for roughly 20 years, and taking fuel dilution into account. It has a large percentage of polymeric VIIs, so it is at a shear stability disadvantage. The stay-in-grade test must not be very tough to meet. I know this is blasphemy.
I would say to my uncertified eye that a less than 2% difference between a 0w40 and 15w40 oil, when all temps are considered, is a no-brainer, but maybe that’s just me. I also may not have been completely clear; I intended to mean a fuel economy gain against an otherwise same winter rating & grade oil. Ex: 0w40 of previous spec vs 0w40 of current spec. Apologies for poor communicationIt meeting MB 229.5 comes with a fuel economy improvement test (1.7%, relative to a certain 15W-40), documented on page 159, as written on the page, here: Afton document
I see a bench shear stability test on page 158. Off the top of my head, I don’t know how brutal that test is.
Some of what I’ve said in this thread is based on memories formed many years ago. Hopefully they’ve held up fairly intact and I haven’t errored too much. Haha. If I have, please point them out so I can re-learn!
