Originally Posted By: Rand
Originally Posted By: Stewie
Originally Posted By: Vikas
Quote:
Are you sure those ain't inch/lb?
725 in-lb? That is 60 ft-lb! Don't you think that is just a little bit low for a 1/2 impact?
As you can tell I am all about the metric system
Some impacts have even less
210 in/lb
http://www.homedepot.com/p/Makita-18-Vol...WT02Z/205577352
Quite expensive too $220 for m18
There is a huge different between those little impact drivers with a hex and a cordless impact wrench with a 1/2" square drive.
You are obliviously highly confused. Your link IS a 1/2" square drive 210 FT-LB impact wrench
The org one is a 700ft-lb high power impact wrench.
The ones rated in in-lb are impact drivers normally used for driving large screws lag bolts etc.
I have a Porter cable impact driver that is rated 1500in-lb
it wont do lugnuts if they are corroded on all winter.
I usually hit them with a breaker bar for a quarter-turn then zip them all off and on with the impact driver.
220$ is not a high price to pay for an impact Wrench with 700 ft-lb.
to get in-lb from ft-lb multiply by 12.
PS. Stewie you dont have an impact wrench
you have a hex impact driver.
Does the job though.
I can't find one in Canuckland under $400
PS: Closest thing I found was 325ft-lb is $700 which would be way cheaper if it were in USD
https://www.homedepot.ca/en/home/p.12--inch--m28-cordless-impact-wrench.1000730445.html
