Originally Posted By: dgunay
Originally Posted By: bmwpowere36m3
Yeah... good luck with that. That's just a 1/4" impact driver/gun... typically used with driver bits (Phillips, hex, square, etc...) and used around the house to screw things. It could remove some smaller fasteners, but
no way in [censored] is it removing lug nuts.
Just because lug nuts are torqued to 60-80ft-lbs, doesn't mean that's all you need to remove them. I would say you need at least 150+ to account for rust and friction (break-away torque).
We have a 1/2" Snap-On and even that takes a sec or two to break-free lug nuts... rated around 200 ft-lbs. Nothing beats the 1/2" air impact SO MG725 1200 ft-lbs.
Yes way... Brushless impact drivers CAN remove lug nuts, and my lug nuts are torqued to 100 ft/lbs. However, I already have 1/2 impact driver so I don't use them for the wheels.
This is what I got last year, nothing special. 130 ft/lb max torque and it removes the lug nuts easily!
https://www.milwaukeetool.com/power-tools/cordless/2653-22
The latest version has 150 ft/lbs max torque, which is even better. And I don't know why you're dragging air impact guns here, but we are talking about battery powered ones but anyways I wouldn't compare both because cordless tools are WAY more convenient, cheaper (no compressor) and functional. Any decent cordless impact wrench is more than enough for automotive.
Milwaukee M18 tools are definitely powerful, but a lot of those specs are like audio amplifiers and peak numbers (like the previous guy mentioned).
So 1/4" adapted to 1/2" for lugs? There's so much flex in those 1/4" drives that I'm highly doubtful. However I'll say I haven't used them all (experience is with Makita and Dewalt).
Personally (and I doubt I'm alone), I would NOT recommend using a 1/4" impact driver for such application in the long term... they might as well not even make 3/8" and 1/2" ones if you can get away with such a small impact.
Let's not bring up price... because my experience is that cordless is not cheap either. My intention was not to compare, just throw it out there. Plus, what decent DIYer, automotive enthusiast doesn't have an air compressor? I kid, I kid. A 3/8" impact driver, yes probably is more than enough for most... if not then grab a breaker bar. My years of working on vehicles says that 3/8" impacts often are lacking and 1/2" very rarely.
