Bad News 1988 4Runner 22RE 217k 20w-50 Castrol
SC
So my question is how bad is this? I didn't have the analysis done because of any issues, was just curious. Had it checked just for this reason. I have only had the truck for the 3k miles since oil change at 214k. No issues at all.
I just changed the oil last weekend and it looked normal, just checked antifreeze looks normal. No smoke... Should I have the compression checked? Where do I go from here. Numbers and data scared me but I seen some others with antfreeze and much higher numbers.
1988 Toyota 4Runner 22RE (2.4 4cyl)
217,762 miles on engine
3,204 miles on oil (20w-50 Castrol)
1.5 quarts added
Code:
ALUMINUM 8*
CHROMIUM 2
IRON 32*
COPPER 13*
LEAD 60*
TIN 0
MOLYBDENUM 20
NICKEL 1
SILVER 0
TITANIUM 0
POTASSIUM 24*
BORON 5
SILICON 21
SODIUM 356*
CALCIUM 1860
MAGNESIUM 13
PHOSPHORUS 791
ZINC 1036
BARIUM 0
PROPERTIES
cSt Viscosity @ 100°C 83.0
SUS Viscosity @ 210°F 16.28
Flashpoint in °F 385
Fuel %
Antifreeze % 0.71*
Water % 0
Insolubles % 0.4
* Indicates out of range
Thanks, for any advice.
Cracked head or headgasket is not uncommon. And there are aftermakket heads available that are supposed to be way better than OEM.
Or even a Heavy Duty 15W-40....hehe. So many people seem to be in the "thicker is better" crowd it seems; at least locally here based on what's always "left over" on the oil shelf.
I'd go for the leakdown and/or compression check first, and see what all 4 cylinders read...could be a cracked head/gasket....
I have had to add maybe 12oz of antifreeze, but didn't think anything about it because there is a very slight leak in the radiator. Usually just damp around the plug drain, doesn't leave a puddle or anything.
Timing Chain and guides were replaced per previous owner about 15k milese ago, but will have that looked at. As I know its the other weak point of the engine.
I actually put Penzoil 10w-40 High Mileage in the truck this oil change.
My concern is whats the chances I have major bearing wear and need a complete overhaul? These engines normally go many more miles with no bottom end issues.
I once drove a 22R with a front cover leak until the oil turned to a substance like Cow Poop (this was a chronic leak over several months) in the end the engine overheated and blew the head gasket.
At tear-down, the rod and main bearings were still not bad.
A major overhaul is not really a big deal with these engines. Last one I did was about $200 parts.
