- Joined
- Sep 21, 2020
- Messages
- 452
And that creates MORE wear, which isn't good for extended life of the transmission. In Honda with it's unconventional automaticsJust to play devil’s advocate here, this is a prime example of why we shouldn’t go playing around with non approved fluids and additives. You stated Maxlife makes your tranny shift smoother than the OE fluid. What Maxlife is actually doing is creating slightly more slip on the friction surfaces, giving the impression that the shifts are smoother.
Then you added lubegard and the shifts became “angry”. Well what happened was your tranny computer realized that there was too much slip going on and it is firming up the shifts to save the clutches from burning up.
which are more like DCTs you don't want more slip, sure you may have more pronounced shifts but it won't hurt anything and the transmission will last a LOT longer with less slip.
