Quote:
I have a perma cool remote mount with a Pure one Filter on it. Should I get a filter with a bypass valve in it? Do I risk my tranny with this filter?
Quote:
Maximum Pressure: 120 psi
• Maximum Temperature: 212° F
Changing filter cartridges is a snap—simply spin them on and off in seconds since there are no bolts to remove.
Install these filters in return lines as well as in off-line filtration and lubrication systems. They have a cast aluminum head and steel canister with built-in bypass valve (the valve is set at 25 psi for nominal-rated filters; 43 psi for absolute-rated filters). Filters also have Nitrile seals and include one filter cartridge (two filter cartridges where noted).
Connections: NPT female. Note: The 1 1/2" pipe size filters have two connections because they have two side-by-side filter cartridges. They also have 2" SAE 4-bolt flange ports.
Nominal-rated filters use cellulose paper media for filtering. Absolute-rated filters use fiberglass media for finer filtering. They have a 99% efficiency rating.
