I recall a few years back the basic Saturn 4 cylinder cars used spin on filters for their automatics. This seems like a great idea; you can get rid of a lot of debris quickly. Why are there no current automatics that use a spin on filter?
Quote:
Gary mentioned something about the sandwich adapter buzzing when used in this manner. Not sure I'll even hear it being that it'll be behind a diesel engine.....
Quote:
well I have one on the way. I am sure it will make more sense when I have one in hand.
Anything wrong with running my filtration on the cooler return line to the trans? I think it's probably highly advisable, given this truck's history with transmissions....
Quote:
Gary - does Amsoil offer a filter that will fit the NT head ?
Quote:
Ah, undummy, The Black Hole. Been awhile.![]()
Quote:
ATF coolers should be cleaned prior to reuse after ALL transmission rebuilds. If so, nothing there needs catching. Mount the filter anywhere.
Trucku, nice filter. Should last a lifetime. What mount PN are you using? does it have a bypass? flow rate of filter? You should paint the filterhead red and add some "Maximilian" details!
