I bought a oilguard auto trasmission bypass filter kit for my Year 2004 7.3 psd (that took 6 months to get here on a slow boat from china!). I already have a deep transmission pan from BD power, with a temp sensor and guage. I also have a auxilliary oil cooler plumbed such that the transmission fluid still goes thru the bottom of the radiator - thru the standard small oil cooler - then the auxuilliary oil cooler and back to the transmission.
It stays cool - even towing in very high ambient temps, never goes above 70C. It seems to take a long while to warm up now in winter so I never hurry her - I just ease along wquietly until things get up to working temps.
If I am to hook up this bypass filter as per the destructions sheet it goes up front somewheres near the radiator on a support panel and hoooks in to the return line from the auxilliary clooler to the transmission?..
Is that OK to do?
It seems as tho - when cold it is slow to change gears - albeit I am not hurrying it, it alsmost has a surging feel to it while cold for a few minutes...
I am not going to damage anything by installing the filter or make the cold gear change surging any worse?
Lets get this right you can barely detect any surging such that sometimes I wonder if I am imagining it!
That said - the truck has almost 70,000 miles on it & when I installed the deep transmission pan, I noticed a LOT of clutch poarticlein the fluid and small metal shavings etc on the magnet in the pan. I installed a new pan filter and changed all the oil which seemed to make a big difference in how the auto trans performed. I also sent off a used trans oil sample at that time to Oilguard and got back an "abnormal" result with high wear metals and clutch particulate matter levels, etc
http://i9.photobucket.com/albums/a70/troutylow/OilguardScreenshot.jpg?t=1183107686
Perhaps you can see the high wear metal readings here!
I see threads 10 pages long here discussing the merits of various screw on bypass and full flow filter kits and admit to being confused! As best I can tell - being installed in the oil line mine nmust be a full flow transmision oil filter because theres no way for the oil to bypass that I can see (No I didn't get a pipe & banjoe ends thingy to connect between the oil inlet and outlets on the side of the transmission in the kit to allow trans oil to bypass!)
So to the question - is it OK to install this kit given what alterations I already have made (deep Pan, and aux oil cooler) into the full flow line?....or will I be restricting the flow of oil further and lead to more surging when cold maybe or wear it out internally faster!
I am just looking for some guidance please - I'm really confused about this from everything I've read so far!
Cheers!
Is that OK to do?
Cheers!
