The oil is a fine motor oil. I've seen VOA's that tend to tell the story that it isn't loaded with a large add-pack, but it will get the job done comfortably well. If you follow your manufacturer's oil change interval any in-house brand motor oil will work (that is api certified, of course). It's when you expect to have extended oci, or need your motor oil to provide something out of the ordinary (better cleaning, premium high-heat stability,etc). If you chose to use the product, be comfortable that you made a good choice.
