Sounds like fun, but would it not be easier to push the defeat button.Our 2018 Equinox is easy to defeat- I just put the gear shifter in manual, then hit the gear shift buttons up to 6th. Shuts the start/stop off.
Our 2018 Equinox doesn't have a button like our 2025 Telluride, and I don't feel like adding another accessory to this car (getting 2 dashcams wired up was a real pain). Since the 'Nox is my daily driver now it's just muscle memory at this point to throw it into low and hit the upshift (+) button 5 times to 6th gear.Sounds like fun, but would it not be easier to push the defeat button.
If you have auto stop/start, is 50 lights/day an average? Above? Below?
This little gizmo was plug and forget. They make one for your 2018.Our 2018 Equinox is easy to defeat- I just put the gear shifter in manual, then hit the gear shift buttons up to 6th. Shuts the start/stop off.
The post office or Amazon delivery are the only ones that I could think of.If you start your car 10 times a day, 384000 starts will take 105 years. I suppose there's some outlier out there who starts his or her vehicle 100 times per day and thusly this milestone will be hit in 10 years, but there's probably not many like that.
Yeah, they could have built a short lag in - so I’m just cutting it off bcs it’s too quick to kill the motor at a lonely stopCars with SS systems do have a heavy duty starter, by disabling the SS system, you essentially end up with a forever lasting starter.
As far as the amount of start/stop cycles these vehicles see per day, it's highly speculative and will vary wildly per use case. I constantly hear cars starting and stopping as people creep forward during traffic or red lights. It could be several times per light for people that habitability creep. So as with many things in life, YMMV.
Exactly! I've had rentals that kill the motor the moment you come to a stop. So if you're making a left hand or tight hand turn and need to creep forward to see the traffic better, it keeps starting and stopping the engine. It's very annoying at the very least IMO.Yeah, they could have built a short lag in - so I’m just cutting it off bcs it’s too quick to kill the motor at a lonely stop![]()
I put one of those ~$10 hood switch bypass harnesses in both my 2021 Equinox and 2021 Traverse to defeat the auto stop/start. Literally a 2min job. Neither of these 2021s has a disable button for the auto stop/start. Both vehicles have about 70K miles on them at this point and haven't auto stop/started since I bought them at ~30K.Our 2018 Equinox is easy to defeat- I just put the gear shifter in manual, then hit the gear shift buttons up to 6th. Shuts the start/stop off.
It's down under--so it spins backwards. Makes it more tolerant of oil thickness.I guess the Australian "electric" oil pump takes a sample of oil before startup and adjusts accordingly. Maybe its AI
That proves they are durable. 384,000 is a lot of cycles. BTW-you are not factoring your time.It's down under--so it spins backwards. Makes it more tolerant of oil thickness.
384k and it needs a starter. After setting a code. Nah, I'd rather have the old school starter back, it might have needed dual batteries to crank in the cold and was apt to die every 50 to 100k--but it was $25 to replace at the corner store if you stacked coupons. And then was free to replace every 10k after that. Way better.
