Auto RX test: before pictures
Originally Posted By: expat
Some of that particulate matter seems quite large, and whats seen in the filter must have passed through the oil pump screen.
How much and how big are the unseen particles
I agree, I'd want something to dislove that junk a bit more. That stuff looks like it can clog a lifter real easy.
I always did a MolaSoak prior to engine clean-up (plus fresh spark plugs, etc), and then a HD dose of LUBE CONTROL LC-20 on a fairly short OCI. Then the ARX regimen with 30W dino and best oil filter. Mine were never so bad as that picture, but two were more than twenty years old (short mile daily drivers). The LC did a good pre-clean, and the ARX did the rest (since 2003).
I, too, would want to do some mechanical cleaning on that motor.
Am enjoying the pics, and here's to good luck!
Originally Posted By: JAG
It looks almost dry. I wonder if the flow to the valvetrain is severely limited. I hope not because that would make it harder for an oil/additive mix to clean it. I also hope the pickup screen doesn't get clogged during cleaning. Low oil pressure would possibly indicate that.
Ermm... Pardon, but does not HIGH Oil Pressure indicate this?
And yeah, Double-dose the A-RX! Recommneded grade on SuperTech oil, change filter at a tick over 1000 miles... WOW!
OP, how far into the cleaning phase are you? How long are you going to run the ARX?
No.
Originally Posted By: Mystic
degree maybe I will actually use the 2 bottles of Auto-RX I still have.
Ill buy em from ya... Why did you never use them?
Were you disappointed with A-Rx?
Originally Posted By: sprintman
I didn't mean 8,000 rpm, I meant don't 'baby' it. Hot oil is required, the hotter the better. And why no before compression test?
Agree...hotter the oil, better that particular type of Ester works.
I am 3300 miles into the clean phase.
I plan to run it to 4k and begin a rinse...
Too short, 5,000 miles at least unless you have a very dirty engine?
Scroll back to page 1 and look at the pics I posted.
Hopefully the ARX can do some things for you, those deposits seem quite "baked" in. Either way, once you're done with the ARX phases, I would stick with HDEO(like Rotella) for awhile. That should help continue to clean it. Also, some MMO 500-1000 miles before your oil change.
Good luck, hope you get results.
Your funny!. Just did a multi bottle cleanup on our 98 Pajero and my 11 yr old daughter and wife can tell it's different (quiet and smooth) and they didn't need 'pictures'.
sprintman- you're funnier, and forgetful, too! Did you already forget that chat you had with your senior engineer about this very subject less than 3 months ago?
Originally Posted By: sprintman 07/23/10 02:51 PM
I get the pictures thing now after a quick chat with my senior engineer. He's an ex American and explained things. All makes sense now I think about it.
I wasn't trying to be funny. Some people take, or like to see before and after pictures to show results, good, bad, or none. Nothing funny about that. Especially when they're on the fence about trying something that costs a lot more than a competitors product used to clean up an engine.
He (Brad Armstrong) has been promoted to consultant (insultant) now. and after 15 years here we have knocked the [censored] out of him, and of course 'the pictures'. There's hope for you yet!
Hope! I don't need hope, but thanks. A picture here in the states is worth 1,000 words they say. Glad the multi bottle clean up worked! Cheers.
