Originally Posted By: Rick20
Yes I have run MMO in my sump. I so no improvement, but then again I wasn't expecting much if anything. My motor was already pretty clean from religious 3000 K OCI's and ARX MD.
No, I never give up. Six bucks worth of ARX run over an entire OCI( maintenance dose), has more positive benefits than 2 bucks worth of MMO for 500 miles prior to an oil dump, IMO.
I don't want for this to continue in the direction it's going, but I tend to agree.
MMO isn't a bad product. I just found it less effective than Auto-Rx. Routine usage probably will prevent some deposits ..remove some. It's not going to be innocuous like Auto-Rx nor provide the extended benefits.
I won't use MMO in my oil after using it and then following it with Auto-Rx and having the results that I did. MMO didn't touch a lifter noise in my Mitsubishi. Nothing did. With Auto-Rx I got new noises I never knew I had and they all went away.
So (probably) routine usage of MMO can give you desired results. I'm just not into altering my oil's properties that much in the process.
I don't think that anyone will experience any harm in a primary sense from the use of MMO on a routine basis. I do, however, reject the idea of using a solvent added to my oil. Not when a much more elegant product is available.
Not everyone has to see value in it. Use what you think serves you best.
