Auto-Rx is a metal cleanser and seal refurbisher. Auto-Rx works on clearly defined ratios over miles. Example transmissions. Ratio is 6 ounces
in your existing transmission fluid. Drive your vehicle 1000 miles and then drain entire transmission including torque converter. There is no need for a second application. Why? Because transmission fluid is a base oil stock with a viscosity of ISO 68 (very thin hydraulic oil) and this is correct Auto-Rx ratio. Cleans everything slowly over miles (cleans seals if not ripped or torn) clutch packs and internal parts of an automatic transmission.
Power Steering Leak - Auto-Rx ratio is 1 ounce per quart of oil (power steering fluid is also very light oil base stock). Drive for a thousand miles and drain. Leak will be gone.
Differential - Auto-Rx ratio is 2 ounces per quart of oil. Drive for a thousand miles and drain. This unit uses a heavy gear oil.
Auto-Rx works on ratios in gas or diesel engines, cleansing oil rotating parts or refurbishing seals takes time.
Auto-Rx is not a purge type chemistry and it is safe, thats why we have a long term maintenance plan.
Hope this information helps you.
