PCM V-Drive Transmission Fluid
Hey I have a 2021 Centurion FI23 wake boat with a GM L96 6.0L engine and a PCM 1.72:1 V-drive transmission. https://marinepartssource.com/power-plus-v-drive-pleasurecraft-marine-ra156013a/
The manual calls for DEXRON III (also explicitly NOT DEXRON VI) for the transmission, which in the past I used Amsoil Signature Series ATF but wondering if Amsoil TORQUE-DRIVE would be a better choice? Or perhaps Redline D4 (or something else).
My understanding is that this single gear ratio (just forward, neutral and reverse) marine transmission is really just a bunch of gears/no clutches so perhaps the D4 may be a good choice since it is also a GL-4 gear oil.
Thoughts?
