Audible Click When coming to Stop After ATF Fluid Change
Arizona
Recently acquired 2005 Pontiac Vibe. Has a history of P0741 code, which comes and goes intermittently. Previous owner had transmission rebuilt a few years ago and then the torque converter in the last two years.
Since purchase, transmission shifts really well and fluid was only slightly dirty. Two days ago, I changed the transmissionmission fluid with Valvoline Restore and Protect ATF. The initial fill was 0.5qt low (as it was 0.5qt overfilled) and I was being cautious. On the first drive, I noticed that I can hear what appears to be the 2-1 downshift. It is not loud, but I can hear it. I believe it's the downshift(TC lockup?) as immediately after, I notice a mild spike in RPM.
The level is now spot on, and noise is still present. Transmission is shifting perfectly up and down the gears. No lurching at all.
Any ideas? I only did a spill and fill, no filter change or pan drop. Not overly concerned, but thought it was a bit odd.
That's a good thought; although it was at around 40% total capacity. Still though, perhaps it is. I've also used Maxlife on these transmissions (at near 100% capacity) without anything like this.
Something in the Valvoline Restore and Protect ATF is giving this fluid a ULV spec nod. Maxlife does not. Could that play a part in it? I am unsure..
I believe that you are the first on BITOG to use this ATF fluid, so thanks for the update!
Definitely something to consider! If it persists; a drain and fill or 2 with proper viscosity fluid should rule it out or solve it. For reference; this fluid is 5.9cSt and the proper spec would be around 7-7.3.
There's a few using it with positive experiences so far if you check out the thread in the ATF section :)
It's definitely in the LV category, if not ULV. I wouldn't use it in a 20-25 year old spec transmission, especially one that "shifts really well and fluid was only slightly dirty". I'd stick to Toyota T-IV or a conventional multi-vehicle ATF.
Never had a problem before, but perhaps this is the "one". I will likely get some T-IV, and see what happens.
When did Toyota switch to WS? Wasn't it around that time? The thinner WS type ATF should be fine with no problem :unsure:
Perhaps you could ass Lubegard to it, and see if that helps.
Update:
Did a drain and fill and used Toyota T-IV. Also dropped pan and replaced filter, 4 qts total were replaced. After a couple hundred miles, the noise persists. I'm not concerned that it's an "issue", transmission shifts very well. Wasted $30 on perfectly good Valvoline Restore and Protect ATF, but an easy experiment.
We actually gifted the car to a family member in need (he has been using my Corolla). He is super excited and it feels good knowing he has a vehicle that is good to go.
