I am at the point to where I believe the NAG1 in my Dodge Charger needs a torque converter. I have changed the TCC lockup solenoid to eliminate the code P0741, changed the conductor plate and cycled multiple quarts of new ATF+4 fluid through the transmission. Hot fluid level correct. I still have mild torque converter shudder in higher gears at part throttle. Sometimes a dead pedal when I attempt to accelerate harder through it as well. The transmission shifts great up and down, no delay going into any gear, no clunks or bangs, no more code. Found no trash or shiny debris in the pan after the filter change. Magnet was fairly clean with no shiny metal.
I am brining the car to an indy mechanic that handles transmissionmission work this Monday. I discussed with him what I have found and have done so far and he seems to think I may be correct.
Can anyone add to: Diagnostic with HP Tuner software to data log his test drive. Unbolt and pull back transmissionmission, replace torque converter, also the price of what he might sell the converter to me for. Approximately 7-9 quarts of ATF+4. Shop supplies, labor, tax. disposal fee etc.
Also thinking of replacing transmission front pump seal at the same time, and entertaining replacing the engine rear main seal as a 'while you are in there' thing. Neither seal is leaking at this time.
