My best friend bought an early Allroad, with the 2.7 V6.
I warned him not to buy it without properly researching it, but he didn't listen to me.
So, in just a couple months of ownership, he had to replace the torque convertor (common issue), air suspension (common issue), and I pulled off one of the EGR valves, and manually cleaned it in order to get rid of the check engine light that was intermittent.
We also replaced the timing belt kit, because he bought it at a cheapo car lot, and we had no clue if it had been replaced or not. Turns out it was replaced recently (within 1k miles) with exactly the same kit we bought.
Changing the timing belt kit was actually quite easy, and yes, you do have to pull the entire nose clip off, but, as long as you followed the service manual instructions step by step, it was easy.
He's my best friend, but he dumped money into it that he shouldn't have, and he didn't research the car before buying it. I warned him before buying it, during the test drive, and all the way up to the point when he traded it in on a brand new CX-7.
He's been much happier since he bought the CX-7.
BC.
