Are you doing the DSG actually I think it’s called S Tronic I said the SG wants and was corrected. Do you have the computer to do the DSG or are you just doing a drain and refill? I had an Indy do it and he charge me 600 he wanted another six for the air filter and the plugs which I passed on. Just an FYI he will need a very thin walled plug socket to get into the spark plug tubes. They are pretty narrow. Also, you will need a very thin 10 mm open end to get the bolt that holds the coil packs in. I had to grind down a 10 mm that I had to make it narrow to fit and I actually had to grind my spark plug socket so it would fit in the hole.
