mf150: that's EXACTLY what I'm saying however 10w30 vs 5w30 is very different from 5w30 vs 5W-20.
Here's something interesting:
for 2000 Crown Vics, they had Romeo built 4.6L SOHC V8s with NPI heads, they used 5w30.
For 2001 Crown Vics, they had Romeo built 4.6L SOHC V8s with PI heads Ford wants 5W-20.
Now the only main difference would be in the different cam profiles and cylinder heads.
For 99-00 Mustang GTs, they had Windsor built 4.6L SOHC V8s with PI heads and used 5w30.
For 01 GTs, they got Romeo Built 4.6L SOHC V8s with PI heads (same exact engine as the Vic) and Ford wants 5W-20.
Interesting that in 2000, a GT would run fine on 5w30 in a superior engine (Windsor engines are better than Romeo engines) then in 2001 Ford wants you to use 5W-20 in a Romeo motor. hmmm
Anyhow, 10w30 vs 5w30 is a totally different issue because we're dealing with cold start viscosities.
In an OHC engine, its IMPERATIVE you get oil into the top end (valvetrain) ASAP. 10w30 MIGHT cut it in warm to hot areas (Southeast, Southwest US) year round, but you cannot recommend 10w30 for year round use on the modular motor.
For the sake of simplicity, I'd just stock up on one oil (5w30) and use that year round seeing how the mod motors run fine on 5w30.
