garageman402
$100 Site Donor 2026
Seems like a pattern with Summit technical specs, as in this thread:
Searching the p/n stamped on your filter mount came up with this. 10 to 11 PSI is what we are calculating. But the package it came in (post 32) has p/n19299222, which Summit Racing says should have a 17-18 PSI bypass valve. Seems like conflicting info and part numbers, but the search result below matches what we're calculating.
