I have an '03 KIA Sedona.
The P/S fluid is "KIA PSF III" which, as many threads here indicate, is probably replaceable with any quality ATF of at least Mercon III specs.
I've exchanged 1 quart through the "turkey baster" method using some left over ATF+4 I have. The color is good and it sounds OK, but cold weather performance is still pretty stiff.
Which ATF would *you* use? Mobil 1? Pennzoil? Multi-vehicle or ATF+4 or Mercon V or Dexron VI?
Inquiring mind wants to know.
