It looks like there is a product "Valvoline Restore and Protect ATF" appeared on Valvolines website. The web page has "noindex" meta tag which tells search engines to exclude it from search results (index). Valvoline Restore and Protect ATF also appears in product finder (for 2014 Audi Q7 at least) which might be unintentional. There are no "Product Information (PI) Sheets" available yet.
https://www.valvolineglobal.com/en/restore-and-protect-atf/
Description
Specs
A few screenshots in case the page goes offline:
Description
Most transmissions are automatic. Now, so is choosing an ATF. Introducing Valvoline Restore and Protect Automatic Transmission Fluid, a premium full synthetic ATF suitable for use in 95% of vehicles. Leveraging innovation from our groundbreaking Valvoline Restore and Protect Motor Oil, the same trusted technology is now available in transmission care. Valvoline Restore and Protect ATF provides up to 97% deposit removal with Active Dissolve Technology, so there’s no need to add a transmission cleaner. Valvoline’s full synthetic formula outperforms conventional ATF with outstanding protection against friction, thermal stability and transmission breakdown. The high performance multi-vehicle protection revitalizes, defends and maximizes automatic transmission life. Whether it’s a Ford, GM, Toyota, Honda, Hyundai, Subaru, BMW, Mercedes, VW and more, you get exceptional performance in any driving condition. For unsurpassed deposit removal and smoother shifting, trust Valvoline Restore and Protect Full Synthetic Automatic Transmission Fluid, from the #1 ATF brand.
Specs
- Removes up to 97% of damaging deposits with Active Dissolve Technology, so you can skip the transmission cleaner
- The #1 ATF brand brings the same innovation from Valvoline Restore and Protect Motor Oil to its groundbreaking automatic transmission fluid technology
- Valvoline Restore and Protect Automatic Transmission Fluid is suitable for use in more than 95% of ATF vehicles in operation with US registered light duty applications
- Premium full synthetic formula with advanced additive chemistry fights harmful friction and thermal breakdown to help prevent costly transmission repairs
- Proven to maximize transmission life, the high performance protection revitalizes, defends, minimizes deposits and ensures smooth shifting
- Recommended for use in applications requiring DEXRON VI, DEXRON III, DEXRON II, MERCON LV, and JASO M315-2013 1A-LV
