My vehicle is new and does not use oil. The OLM will probably not indicate an OC due until 7000 miles or so and I figure the oil consumption, if any, would be slight even up to that mileage.
But lets say your vehicle does use a little oil between OCIs. When do you add oil? Do you top-off when the dip stick shows 1/2 qt. low? Or do you wait until it is a full qt. low? I assume there is no problem with it being a tad low between OCIs but I would think you need to do something at the 1/2 qt. level (unless you plan on changing oil real soon). What do you all think and at what point do you top-off?
