ARx Rinse- Cycle Begun
Dover,DE
Well I did the oil change after running the Auto RX for a little over 1500 miles. The AutoRx was in with Chevron 10-30 in my 98 Volvo V90(960).
I used Supertech 10-30 for the rinse cycle. I believe it to be Mobil DC as the refinery is right up I-95 from here.
I'm chasing a sticky lifter or a sticky valve.
I heard it yesterday loud and clear. So the AutoRx did nothing for it in the cleaning cycle.
I'm also running a bottle of Redline SL1 through the gas tank.We shall see.
I did pretty much the same thing on my wifes 98 Stratus 2.5L, trying to rid the engine of either a sticky valve or a sticky lifter (some ****ed tapping noise).
It used to only pop up when the temp was below 50'F, but last winter it got bad enough to be noticable all the time, regardless of engine temp.
The noise was cleared up by the end of the cleaning phase, just started the rinse.
G
So in the other thread you made about Auto-RX you are calling it snake oil even though you haven't even finished the rinse cycle?
Comon now, what the **** is wrong with you.
It's like having a headache and popping a Advil and bitching that the head ache is not gone 2 seconds after taking the pill.
Grab some patience and see this through.
