Originally Posted By: Shannow
Originally Posted By: JHZR2
Though I have to think there is a problem with shannow's comment...
Most of the wear takes place when the oil is flowing to all of the places that it needs to go, and 0W at 32F isn't going to make any difference whatsoever.
Perhaps should be:
Originally Posted By: Not Posted by Shannow
Most of the wear takes place when the oil is not flowing to all of the places that it needs to go, and 0W at 32F isn't going to make any difference whatsoever.
After all, the marketing geniuses drill into us that some non-trivial percentage of wear occurs at startup.
Nah, you shouldn't have misquoted me with something that's incorrect.
For example, the industry standard wear test the sequence IVA is precisely what I described. An engine with full oil flow to all points that it's needed, and forced to operate in "warm" rather than hot conditions.
To quote a member who has actually performed these tests "the perfect storm"...where viscosity is dropping, and additives aren't fully functional.
I like the question of differences at temperature. I think if we were to dissociate wear into some set of events:
X meters of sliding contact due to improperly lubricated surfaces
Y number of contact events at n psi due to uncushioned interfacing
Z number of improper actuations due to insufficient pressure
Then we might be able to link a viscosity requirement and assumed exponential decay for each type.
So then the question becomes, how long until hydrodynamic lubrication is achieved for each of these at each temperature, and what's the effect of the time prior? Beyond some temperature and with each viscosity range, the returns will become so diminished, along some curve/surface, that it's irrelevant.
Lubricants in their easily pumpable range, i.e. above freezing from everything from 0W to SAE30 will do exactly the same job at filling the galleries, and "getting there", and establishing hydrodynamic lubrication (in the places that are lubricated by hydrodynamics)
The MRV of an oil is it's ability to refill the oil pump at lowered temperatures, CCS is the ability for the engine to crank to starting speed (is a high shear rate test).
As you drop temperatures, different "W" grades become unpumpable and fall out of the realm of being appropriate oils...and yes, they will cause excessive wear and damage, obviously.
But again, except in the case of oils that won't pump, the wear is predominantly in the period after the engine has oil pressure and flow everywhere, not the hundred or so revolutions that the engine is spinning on the left over (highly viscous I might add) from the last run, and held in the rings and bearings by capillary action...ever pulled apart a dry engine ?
But even then, I suspect that pumping losses come into play. My understanding is that GM started the move from 10W- oils to 5W- not because of startup wear benefits at normal and common/reasonable temperatures, but rather because a bit of fuel economy could be squeezed out...
Yes, the switch to higher VI oils is to eek out a bit of economy, but the "pumping losses" that people are enamoured with aren't the reason.
Raise the oil cold pressure from 60psi to 80psi, and the difference is 50 watts or so...nearly nothing. The power losses that viscosity causes are in the bearings, piston skirts and rings...they amount to thousands of watts of wasted energy.
Tiny piston skirts clearly point to what they are trying to achieve here. And the Honda papers, and a couple of Toyota papers are quite clear in that's what they are intending to do with their high VI fares.
GM could well have pushed 5W30 for it's higher VI but the "W" grading doesn't promise this...look at M1 0W30, 5W30, and 10W30...about the same viscosity, same VI, just one of them is suitable for -40C.
Some reading that you might undertake on warmup wear.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4049050/Re:_75__of_wear_occurs_at_star
First off, you weren't misquoted if taken within the context of my entire post, where I suggested it as an edit.
Second, the question posed which I found interesting was not in the realm of a "mid temperature" IVA sequence where the base oil viscosity has dropped due to temp, so hydrodynamics are worse off but the adds aren't activated. I get the point of that but that wasn't the question asked. I agree with you that at freezing, at typical "ambient temps" (nonwinter), it's irrelevant but the -10F, and -20F type conditions??? To me that's another interesting realm.
I get the basis of your commentary that at the expense of friction (Streibeck to the right where friction starts to increase again), excess viscosity prevents wear in many circumstances.
However the other side of the coin - fluids in marginally pumpable scenarios, is more of the point here. I've seen the comments that a lube is pumpable or it isn't. But I guess folks haven't seen viscous lubes working in sliding and rotating machines where they just don't get from point a to point b fast enough to prevent contact and higher scars in those locations. This happens on simple sliding equipment for that very reason, and similarly can occur on camshafts and bearings. When the pumping viscosities are defined in terms of flow where the time constant is on the order of minutes, the duration has gotten too long. And it's not necessarily instant at temperature T and then no flow at temperature T-1. I don't concur that excess oil left sitting is good enough for much besides corrosion protection. Sure, it's there, but it's not active, moving, or necessarily pumping at the start when really cold.
So, some locations, maybe not all, hopefully not many, may well have a condition where the lack of pressure/flow creates a condition where the nearly dry surface can have contact and thus wear which would not happen if full flow was occurring all over (regardless of the temperature). The time to get to full flow all over is therefore still of interest, regardless of how much remnant viscosity is believed to still be there by a stagnant film.
