Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,975
Did they send them all to the ME for "emotional support". I'll see my way out.The goats might chew wire and dumb things they do …
There might be a goat shortage now anyway![]()
On one hand, I feel bad for them, but on the other, they had to realize that almost anything could have ended up there in their backyards. Zoning can always be changed so that doesn't always protect either.... The houses across the street from us have a hay field behind them. In their case though, I believe it's too small and "road-locked" for anything other than more housing to end up there. There is a cul-de-sac in the lower left where a street could continue off of to turn into the field. It would require purchasing the wooded lot too though. That's someone's property with their home though, so unlikely....Those people probably bought those houses because there was a corn field behind them.
They're not "taking away" farms or farm land and the same applies with solar farms. Remember - who sells them the farm land to build these ? The farmers do....Data centers are taking away the farms that occupied the land.
Just because there is a land that has previously grown stuff, doesn't mean it will forever be suitable to farm.They're not "taking away" farms or farm land and the same applies with solar farms. Remember - who sells them the farm land to build these ? The farmers do....
If they don't have enough water they will just sit there regardless
Was not farmed until the Colorado river project brought subsidized water to them.In California we have almond farms using up water and then in drought the trees die. Yes it is "farmland" but there is not enough water, nutrient (due to past over farming), labor, whatnot to continue using it as a farm. Using some of it for solar is actually a way to save up water for the rest of the "farmland".
Depends on where you are.A bunch of the new ones are doing closed loop cooling, not evaporative cooling. Evaporative cooling has efficiency limits with these very dense power numbers.
I think your on the East Coast. Evaporative cooling doesn't work here. Too humid.
Not for evaporative cooling, its pure science. All you need to know is the wet bulb and dry bulb temperature and a psychrometric chart. It really isn't efficient above 40% relative humidity and pretty much stops working altogether at 50%. There is essentially no US state East of the Mississippi with average summer humidity in range.It's super hard to blanket statement things about what does and doesn't work.
How are you defining evaporative cooling. What is your inlet water temperature?FWIW: I'm literally standing in a data center, in Ashburn VA, that uses evaporative cooling. We aren't overheating, so it clearly does work.
You said evaporative.It sounds like you're focused on direct evaporative cooling, there's also indirect evaporative cooling.
In this building, there are 42 indirect evaporative cooling units that cools 2800 racks.
Indirect evaporative is a heat exchanger. No one calls it that - they call them heat exchangers.
Where does the water come from for that? And how much water does the building go through in a day?It sounds like you're focused on direct evaporative cooling, there's also indirect evaporative cooling.
The one in Desert are likely solar panel powered, just like the one in Las Vegas my employer uses. If your workload align with daytime sunlight it can get VERY cheap.I'm for them but only in places that already have lots of water, which does NOT incude AZ's Sonoran Desert.
AC is a phase change cooling system, yes it's a direct evaporative system, but it's closed loop, so the phase change happens over and over again.You said evaporative.
Indirect evaporative is a heat exchanger. No one calls it that - they call them heat exchangers. The cooling loop in your car is a indirect evaporative system. So is the AC in your car, and the AC in your house. Your coolant doesn't rely on evaporation. In fact it sealed and doesn't evaporate at all. Very different.
And when it comes to data centers, I kind of get that. But in this case, the proposed data center location is separated from the nearest people, as small farming community of perhaps 250-300 people, by about 10 miles and a mountain range. Without driving out to the desert, no one will ever see or hear this data center. The nearest highway (Interstate 84) will be about 7-8 miles away, so the data center may be visible to those traveling on the highway, but not in their normal view.I love that people are for them as long as they are in someone else’s backyard.
Unless eminent domain is used, I don't see how that applies. In this case, the land owner is willing to sell his ranch to the developer. And although I have no personal knowledge of this particular instance, I know most of the aging farmers and ranchers in Western Box Elder County would be thrilled to have someone willing to buy their land at a fair market value.Data centers are taking away the farms that occupied the land.
